Why do we have to pay for unanswered phone calls?
- Home Phone
- Re: Why do we have to pay for unanswered phone cal...
Re: Why do we have to pay for unanswered phone calls?
06-09-2013 8:33 PM
I have just found that we are also being charged for calls to mobiles that are unanswered, the reason I know that is if I can't locate my pnone in the house or car I simply ring it to fins it, "I 'don't answer it" and ring off well before the auto answer cuts in. . I have just discovered I have been charged 26p on every occasion for the luxury, I wish I had known that this was Plusnet policy, we never got charged by TALK TALK for the same process in 4 years. The information you post about OFcom not allowing call charges unless it is connected is particularly interesting as I cannot see TALK TALK missing an opportunity to charge 26p for every unanswered call to a mobile. I am a member of WHich? consumers association and intend to see what they say, also Money Saving Expert as it isn't cheap. I am disspointed PLUSNET you had been doing so well for us and our house move with BB went v smoothly.
The only reason I noticed was I was looking into why I was paying 33p to a number 123
07-09-2013 3:56 PM
Quote from: lizzyhoo Hi,
The only reason I noticed was I was looking into why I was paying 33p to a number 123on 5 occasions between Dec and May, but I will post separately about that, and the only reason I noticed that was I paid £6.75 to call 118118 for 2 minutes for the first time in a very long time, well if that's how much it costs wow no wonder thaey need to advertise incesantly.
Your not alone
Because of your post I checked my calls and noticed I got charged 0.10 for a 00.00min call to my mobile to locate it back in May 18th at 00:38:50
Bit of a swiz really but not going to loose any sleep over it. But worth knowing that Plusnet charge for unanswered calls to Mobiles
dick:green Quote tags fixed.
07-09-2013 4:32 PM
One of the guys will be able to double check that during the week for you though
07-09-2013 5:23 PM
It probably explains why my unanswered call lasting 1.63 seconds cost me 22p even though the relevant mobile phone did not answer or register a missed call.
Just a thought!
07-09-2013 5:37 PM
Will update after a day or so to give it some time to filter through .....
07-09-2013 6:53 PM
07-09-2013 7:28 PM
07-09-2013 8:46 PM
08-09-2013 7:43 AM
Quote from: Scott That sounds like a text message sent from the landline to be honest pennbank, rather than a call. They show as 0 minutes and as 10p on the itemised bill.
Ah did not think of that one, may be I was testing it as I did set the thing up for that
As I said No worries, but hey thanks plusnet for mentioning it.
Regards.
08-09-2013 9:58 AM
08-09-2013 10:38 AM
08-09-2013 11:39 AM
Just checked the mobile and indeed it was a text message as I had just set the SMS up and was checking I had put in the correct service centre numbers for the thing to work.
With apologies It would appear that Plusnet do not charge for unanswered calls to mobile numbers unless they get answered.
08-09-2013 11:52 PM
Quote from: spraxyt I tried an unanswered call to my mobile at 11:15pm (06/09/2013). The mobile registered it as a missed call but it hasn't (so far) appeared on my home phone recent calls list…
Subsequent (answered) calls to the same mobile number have appeared with an appropriate charge but the unanswered one hasn't. So in my case unanswered calls do not appear to be charged.
09-09-2013 7:58 AM
Does the original poster have some kind of call diversion in place ?
09-09-2013 9:38 AM
Quote from: picbits Does the original poster have some kind of call diversion in place ?
See my Reply #13 for the answer
- Home Phone
