Why Change
- Home Phone
- Re: Why Change
Why Change
01-11-2007 9:17 PM
I have a BT phone account paying by DD,it costs me about £17/month,50% of my calls are daytime (8am-6pm) the vast amount of my calls are 01 numbers.I have a PN option 2 broadband account at £14.99/month,can anyone tell me if I stand to gain anything by changing ,as it seems quite complicated to understand the tariffs and Looking at the options can I have option2 BB and anytime phone,it doesn't seem clear.If I changed would it entail a problem getting from BT to PN.
Message 1 of 5
(2,664 Views)
4 REPLIES 4
Re: Why Change
01-11-2007 9:23 PM
Firstly, changing over would be pretty simple and should take about 10 working days.
Whilst I really couldn't say how much your bill is going to be, on the evening and weekends package, I would expect you to save a little bit. Why not try it and see? It's on a monthly contract.
Message 2 of 5
(836 Views)
Re: Why Change
01-11-2007 9:29 PM
Thanks James I'm thinking Very Slowly
Message 3 of 5
(836 Views)
Re: Why Change
02-11-2007 2:48 PM
One answer I could not find was do I have to contact BT when I change over and would they want a charge for freeing my line.
Message 4 of 5
(836 Views)
Re: Why Change
02-11-2007 2:52 PM
There's no absolute need for you to contact BT, unless notice is required as part of your contract. They will be contacted when the transfer order is accepted, and again when it completes.
There's not normally a charge for transferring away, although that will depend on any contractual obligations you have with BT at present.
Message 5 of 5
(836 Views)
