Where is the \ key on my phone keypad? - trying to set up Call Divert
chunkin
Hello All,
I just activated PlusNet's call divert feature and have read the instructions on how to set this up. The instructions say:
Using Call Divert
There are three codes you can use, depending on what you want to do:
  • 21 diverts all calls
  • 61 diverts calls you don't answer in 15 seconds
  • 67 diverts calls when you're on another call
If you want to... Here's how you do it
Set up Call Divert Press \*(Code)\*(Number to divert to)#
Check Call Divert Press \*#(Code)#
Turn off Call Divert Press #(Code)#
My question is:
Where is the "\" key on my telephone keypad? I do not see this key ! Is there an equivalent button?
Any help would be greatly appreciated! Thank you!
C
6 REPLIES 6
Re: Where is the \ key on my phone keypad? - trying to set up Call Divert
@chunkin - Do you really need it is it not being used as a separator i.e.
Step 1 #CODE
Step 2 *NUMBER TO DIVERT#
or
Step 2 #CODE#
Can you try this please.
Alex
Fixes: 13
Also, if you can post the model of the phone you use it'll help.
I'm mainly an iPhone person so can help if you're using that, but wouldn't be able to otherwise.
Mav
Fixes: 515
@chunkin
Have a look look at this thread as it appears the use of "\" is a typo.
Edit: Or as @Anonymous says it is used as a separator.
Forum Moderator and Customer
chunkin
Thank you all! It worked without the \
As mentioned, i believe this is a typo in PlusNet's instructions!
Fixes: 1,600
I'd like to get this fed back to the relevant team. Mind sending a link to the page across to me?
Anoush
Mav
Fixes: 515
@Gandalf
There's a link in the thread I referenced aboveWink
