Where did my dial tone run off to?
warbleeder
no dial tone for just over 5 minutes?
whos at fault?
was just on a call came off and no tone got someone to ring it for me and it gose to voicemail?
6 REPLIES 6
warbleeder
Re: Where did my dial tone run off to?
just come back on almost 10 mins downtime?
orbrey
Not sure what was going on there, all the orders on your phone line are complete and I can't see any faults open... very odd. I guess someone working at your local cabinet or possibly the exchange as I don't believe we've received any notification of works going on.
kmilburn
Think yourself lucky warbleeder,  mine's been awol since wednesday!
warbleeder
np matt thanks for reply having some problems with estate agents so need phone for contacting sheltr and cab ect
Oldjim
Fixes: 63
I have had that a couple of times when the person I was speaking to (they called me) didn't hang up at the end of the call.
After a pre-set time - I don't know what it is - the automatic systems cleared it
picbits
Quote from: Oldjim
That would be my guess - have you tried dialling in to your number ? If it rings but your phones don't then you have a line fault.
If it's engaged or you go straight through to the voicemail then your line is still in use.
