What will I be charged for?
xreyuk
Hi Guys,
I've opted to take line rental saver, and line only (so no call package) with Plusnet.
I understand numbers like 0845, 0870 are chargeable, as are your normal 01, 02, 03 and 07 numbers.
I know calls to Plusnet, 1471 and other Plusnet customers are free, however, I wondered if 0800 numbers are free to any company?
Also, is there a way to de-activate Plusnet voicemail? I have an answering machine on my phone.
Thanks.
6 REPLIES 6
ITWorks
Fixes: 9
Re: What will I be charged for?
HI,
You can de-activate Voicemail, from the call features page here:
https://portal.plus.net/plustalk/index.php?page=wlr_remove_call_features
Yes 0800 numbers are free
Kind Regards
Mike
xreyuk
Thanks :), you can do quite a lot from the member centre can't you? Cheesy
petecov44
99% of stuff as it's directly linked to the internal system as you would expect.
KevinG
Quote from: I
And 0808 and 0500.
tj47
Having renewed my line rental in advance, is there any way that I can see that payment recorded in the Member Centre?
Oldjim
Fixes: 63
It should be under Closed Questions
