What's this on my phone line?
- Home Phone
- What's this on my phone line?
24-09-2020 1:24 PM
It's really old and it's always stopped the front door from fully opening, so I'm thinking of replacing it with a newer smaller version. Any idea what to replace it with and how hard it would be? It looks like it'll fall to bits if I attempt to open it.
Re: What's this on my phone line?
24-09-2020 1:35 PM - edited 24-09-2020 1:36 PM
24-09-2020 1:37 PM
Welcome to the forums.
Is it a sort of grey in colour with wires coming out both sides. and is it before your Master socket?
If so you must not touch it, you need to report it for a repair/replacement. I have one here its where the phone line used to come into the property, its pretty old, the other side has wires going to the Master BT socket.
I assume as you are with PlusNet your phone service comes via them, so you need to let them know.
24-09-2020 1:39 PM
Now seen your photo, came in while I was typing my other message, and you need to get OpenReach engineer out to fix it, via PlusNet. If is broken.
24-09-2020 1:54 PM
I'll report it if it gets too brittle.
24-09-2020 1:57 PM
As it's on the Openreach side of the master socket you shouldn't change it. However there's nothing to stop you glueing it back on the wall and let's face it for a more permanent job no-one would know if the top was taken off and without touching any wires it was screwed to the wall.
If you call out Openreach then when they get around to changing it/glueing it back on the wall (their choice as it's their property) there's a risk that you could be charged.
- Home Phone
