What phone can I use ? what can I do?
- Home Phone
- What phone can I use ? what can I do?
26-11-2010 2:26 PM
I have hads to plug my router into the test socket and now my phones in other rooms do not work. what can I do? any ideas?
Message 1 of 5
(948 Views)
4 REPLIES 4
Re: What phone can I use ? what can I do?
26-11-2010 2:27 PM
:Plug the phone into the filter in the test socket
Message 2 of 5
(201 Views)
26-11-2010 4:21 PM
Thank you Oldjim. Yes, that does work, and in fact it is working, but my phones are all wired into the house and I need more than one phone. the others are not working.Any other ideas?
Message 3 of 5
(201 Views)
26-11-2010 4:34 PM
Unless you go and buy a DEC phone set then you are stuck with only one phone while using the test socket unfortunately
Message 4 of 5
(201 Views)
26-11-2010 5:25 PM
If you have another filter, plug that into the first one. Then plug the faceplate into the second filter.
Double filtering shouldn't cause any problems. If triple filtering is an issue, remove the filters from the extension sockets.
If you want the best seat in the house, move the cat
FTTC 40/10 Billion 8800NL
BT technician (Retired)
Message 5 of 5
(201 Views)
- Home Phone
