What is the maximum time that a pensioner should be without a working telephone?
- Home Phone
- What is the maximum time that a pensioner should b...
01-10-2013 10:58 AM
So far 27 hours .... 24 hours since the call was raised and attracted the response "Awaiting Support Team Answer"
Not even a "passed to engineer" ... that no doubt has still to come ...
Subsidiary question ...
How long between a customer extolling the virtues of his supplier and actively looking to move to another?
Re: What is the maximum time that a pensioner should be without a working telephone?
01-10-2013 11:01 AM
Also you might want to change your display name before you fall foul of this: http://community.plus.net/forum/index.php/topic,218.0.html#post_derogatory
I'll get someone to look at your fault ticket shortly.
01-10-2013 11:03 AM
Unless they are on some sort of "at risk" or "vulnerable" register.
My very old, frail and vulnerable father-in-law is registered with all the main service suppliers in that way as he lives "home alone".
In addition we have left PAYG mobile handsets in strategic positions, permanently switched on and on charge as a backup. And of course there are appropriate contact arrangements with neighbours.
01-10-2013 11:06 AM
01-10-2013 1:35 PM
As a matter of principle I find it is handy to provide a (correct) link to the page you want someone to action.. rather than a link to a large generalised store of information.
Have I missed something?
One of the reasons I have been a stauncn Plusnet supporter in the past, was the quality of it's helpdesk.
One raised a call .. via email ... so you didn;t have to spend hours on a phone .. tapping this and that and explaining the symptoms over and over until one happened upon a competent individual.
The call was acknowledged immediately, and someone looked at the problem .. and posted a sensible reply .. detailing what needed to happen next.
Do I understand now that since the BT takeover .... one raises the call... gets the response .. awaiting support team response... then one is expected to discuss it in the Forum until someone is sufficiently picqued to take an interest?
This does not sound like a sensible strategy.
But if you wish to pursue this in a punblic forum then so be it.
I am glad to hear that you have decided an engineer is required .. that was where I was at yesterday at 11am ....
Is Thursday OK ...
Yes ... we may be in.... does the engineer require access ?
This will be 3 days without a phone service, do you regard this as an acceptable level of service?
Please can you provide a MAC key
01-10-2013 1:48 PM
Long way round
Click on profile at the top of this forum
Then account related settings on the left
Click on that and you can change the display name
01-10-2013 2:00 PM
Could I suggest that this shows an increased dissatisfaction with the way support is working.
The ONLY reason I am here on the Forum is that the normal flow of information regarding a specific fault is not happening on the call ...
This information flow was the reason I came back to PLUSNET.
One could track one's call and the actions being taken.
I now appear to be in a situation where I have a call ..... as I have no phone service..
and the helpdesk is saying "awaiting support team action" as it has done since the call was raised.
Meanwhile on this Forum .. I find that someone has actually looked at it, decided an engineer is required .. as even scheduled one ...
If this was on the call then you would not have this irate customer (I take great exception at being labelled a spammer) banging on... in fact you may have a customer patiently awaiting the engineer.. rather than one determined to move to a supplier with a helpdesk which does what it says on the tin.. and doesn't rely on mob rule and cyber-bullying to set it's priorities.
01-10-2013 2:07 PM
Quote from: Minusnet1 I see that the rules of the forum are being changed due to the actions of spammers and "bumping"
What are you on about? If you look at the bottom of the rules post it says " Last Edit: Fri 06-09-2013, 09:21:00 by Oldjim"
Edit: For independent confirmation of that I suggest you go to http://web.archive.org/web/*/http://community.plus.net/forum/index.php/topic,218.0.html to see when the rule(s) you think are being changed were actually last changed.
01-10-2013 2:07 PM
why doesn't the link in the email work?
Why send a link which doesn't work ? What is the point?
have you ever tried to follow instructions provided in this way ? I am on a page reading
"Click on profile at the top of this forum
Click on that and you can change the display name"
I do as requested and click on the profile at the top of the forum ... can I still see the instructions ?...
This is supposed to to simple....
I trust that the tone of this response gives some indication of the irritation I am feeling ... not so much because of the fault .. which is iorritating enough in itself.. but far more that the process which is being followed is so poor.
01-10-2013 2:14 PM
PM is a Private Message (accessed from MY MESSAGES).
You should be able to right click PROFILE and open it in a new window or tab.
Edit: I see you've succeeded!
01-10-2013 2:14 PM
Quote from: SousSeine
Well I just checked those instructions were correct (they are) and managed to remember the 3 relatively simple steps.
Alternatively, write them down or just open another tab in your browser then you can see both instructions and effect.
Useful tip: In most browsers you can "right mouse click" on a link (e.g. Profile above) and choose to open it in a new tab or new window - quite handy at times.
01-10-2013 2:27 PM
Quote Yes ... we may be in.... does the engineer require access ?
The engineer has been booked for Thursday am. He may require access to the premises, however that depends on whether he can find a fault elsewhere along the line. Sorry it's 2 days away, however that's the earliest Openreach engineer available in your area for a fault.
Quote Please can you provide a MAC key
We don't accept MAC requests via forum. You'd need to either call us (I know you have a fault at the moment) or write a letter as you've been advised in a different thread.
01-10-2013 2:35 PM
Interesting that remembering list, and / or writing them down ... are still regarded as the way forward ..
Makes you wonder why we buy computers ...
To return to the original question ....
how long m....... without a phone ?
Do you think that "at least 3 days" is a reasonable response?
Im understand the difficulty in having to frontend to iarte customers when the guys who can do the work are external to your organisation... I suspect that it is these same guys who have caused the problem in the first place ...
BUT
I see the help assistant is still saying "Our Support Team will respond to your question soon"
One is tempted to ask whether there are any measures of how long Plusnet staff spend on the Foirum.... rather than the Help Assistant...
And whether this ratio is increasing or decreasing
Please email me with the MAC key instructions ....
I have other things to do
01-10-2013 5:03 PM
http://www.plus.net/supportpages.html?a=212
Services for Disabled and Elderly customers are shown here:
http://www.plus.net/support/service/code_of_practice.shtml#elderlyAndDisabled
12-10-2013 11:16 AM
Here is the link for you: http://www.plus.net/support/customer_service/using/request_mac_key.shtml
We have dedicated Faults Teams who deal with Broadband and Telephone Faults. The Faults Team aim to get back in touch within 48-72 hours - this is within the Service Level Agreement which is agreed to when you sign up with us.
If there is anything further we can do to help, please do let us know.
- Home Phone
