Weekend tariff
- Home Phone
- Weekend tariff
Weekend tariff
04-06-2015 4:43 PM
Hello,
I am on the Weekend phone tariff.
I wanted to ask.....how much would it cost me to call someone on a weekend?
I'm just confused about the tariff as I'm not sure if it's free all weekend or only free to certain numbers....etc.
Many thanks.
Many thanks.
Message 1 of 7
(2,076 Views)
6 REPLIES 6
Re: Weekend tariff
04-06-2015 4:54 PM
Hey Spooky,
Apologies for not counting the o's in your username.
This probably could explain it better than I can. Though let me know if that doesn't clarify well enough.
Matty
Matty
Message 2 of 7
(1,075 Views)
Re: Weekend tariff
04-06-2015 4:56 PM
Tariff details here:
https://www.plus.net/home-broadband/tariffs/weekends
Remember that calls are only free for up to 60 mins. After this, redial or you will be charged for the time exceeding an hour
Quote UK landlines Inclusive at weekends
UK Mobiles 100 inclusive minutes available for £3 per month (for packages taken on or after 8th May 2013)
Non-geographical numbers (0845 & 0870) Inclusive at weekends
(Calling cards, indirect access and dial-up Internet numbers are excluded)
Plusnet to Plusnet calls Inclusive at all times
Calls to Plusnet support Free at all times
Message 3 of 7
(1,075 Views)
Re: Weekend tariff
06-06-2015 10:20 AM
Thanks you two
and Matty....it's fine, you can put as many 'O's' to my nickname if you wish to
I did read that but am still confused by the "inclusive" part!
I see that it's similar to what BT does......after 60 mins, hang up and redial again for another free hour of call?
Many thanks!
Many thanks!
Message 4 of 7
(1,075 Views)
Re: Weekend tariff
06-06-2015 12:04 PM
Hello there Spooooky (number of o's counted because I'm pedantic like that ;))
I'll try to clarify the Weekend plan for you as best as I can.
You can make free calls to UK landlines (any number beginning 01, 02 or 03) at anytime on Saturdays or Sundays, as long as each call doesn't last longer than 60 minutes. As you've rightly pointed out, it's BT's "hang up and redial" system. You can also call 0845 and 0870 numbers during this time, again, so long as the calls are no longer than 60 minutes.
If you know someone on Plusnet, you can call them free at anytime (60 minute rule still applies here) and you can call Plusnet support free forever and no matter how long you're talking to us, you won't be charged.
Hope this clears everything up
Message 5 of 7
(1,075 Views)
Re: Weekend tariff
06-06-2015 12:58 PM
*/sigh
https://portal.plus.net/home-broadband/faqs/broadband-and-phone/#included-calls
Quote Do I get any included/free calls?
Inclusive calls are for numbers starting 01, 02 and 03, 0845 and 0870 (some exceptions apply).
These calls are inclusive:
24/7 with Anytime
Between 7pm and 7am weekdays and all weekend with Evening & Weekends
All weekend on Weekends
Note: Calls become chargeable after 60 minutes, redial to avoid call charges.
Message 6 of 7
(1,075 Views)
Re: Weekend tariff
17-06-2015 3:40 PM
Quote from: catelliott Hello there Spooooky (number of o's counted because I'm pedantic like that ;))
Hope this clears everything up![]()
Thank you so much
Message 7 of 7
(1,075 Views)
