Warning about high (25p) cost of calls to NVS/G21 056XX VOIP numbers
racquel
Just a note that if someone gives you an 0560X number to call, not only won't it be included in your package, but it'll cost you 25p to make the call, and another 9p/minute after that from Plusnet, and significantly more from mobiles.
These are sometimes referred to as NVS numbers making the tariff hard to find, but their correct designation is G21.
These numbers often come "free" with BT packages, and are given out free by some VOIP providers.
Learnt the hard way - just be aware!
