WHATS HAPPENING??!! Phone keeps ringing and line is in use!!
- Home Phone
- WHATS HAPPENING??!! Phone keeps ringing and line i...
06-10-2015 12:04 AM
I switched over from BT broadband, to Plusnet fibre extra and plusnet landline. Both switched over today, had the engineer come out today and set up fibre. I have noticed a problem which is happening now since this evening.
7pm - Landline rings once. I answer and there is no one there. So i hang up.
7.15pm Landline rings once. I answer there is no one there. So i hang up and dial 1471. The automated service tells me of a call i received at 2pm as my last call.
11.30pm Landline rings once, i answer, there is no one there. I wait and hang up. I try to dial 1471 but i shows on my phone the line is in use. I put the phone to my ear and there is no dial tone.
11.40pm I try to dial a friend but the landline is still in use, then the off the hook alarm sounds. I hang up and try again and the alarm is still sounding.
11.50 i try to dial out again but there is loud noise on my line.
LED screen on my phones shows that my line is in use..... I have 3 cordless phones in my house, i am not using my phone, so how is my line in use??? Did the engineer mess up outside in the cabinet or inside my property when wiring???
I tried trouble shooter but it says an "opps error, dial 0800..." which is not closed.
What the hell is going on??? I dont want to be woken up in the middle of the night by this so unplugged my phone.
Message 1 of 3
(3,540 Views)
2 REPLIES 2
Re: WHATS HAPPENING??!! Phone keeps ringing and line is in use!!
06-10-2015 8:06 AM
Does dialling 17070 tell you the correct number?
Message 2 of 3
(2,829 Views)
06-10-2015 9:11 AM
There's no longer a dial tone on my landline. I tried calling my landline via my mobile and it goes straight to voicemail. I contacted plusnet this morning and they said they need an engineer to visit the property as there is a fault.
Fault Type: NDT
Test Results: LOOP CONDITION DETECTED (UNPLUG ALL END USER EQUIP and RE-TEST)
Fault Type: NDT
Message 3 of 3
(2,829 Views)
- Home Phone
