Voicemail problem
rob80
Voicemail problem
Dialling 1571 just gets me an engaged tone and no messages or options. It was working ok up to now. Please investigate to reinstate. This has happened previously and you were able to fix it.
2 REPLIES 2
Fixes: 251
Re: Voicemail problem
Can you dial out to any other number?
If not, then it’s likely that there’s an exchange issue, possibly impacting a number of users.
Try dialling in from a mobile phone - see if that clears the issue.
rob80
Thanks for your reply. Yes I can dial out to another number. Dialling in from my mobile didn't clear the issue. Landline just rings for a while and then goes to engaged tone with no invitation to leave a message.
