Voicemail not working
Abzlady70
Can anyone help with a Voicemail issue?  I came home today to find that we now get a dead tone when I dial 1571.  It was working fine yesterday.  I've checked my account/package and we are still signed up for Voicemail.  Any ideas?
7 REPLIES 7
Fixes: 387
Re: Voicemail not working
Can you make any outgoing calls/do you have a dial tone on the phone? If the answer to either of those is 'no', report a phone fault via Report your landline problem | Help | Plusnet
Abzlady70
Hi John, we have a dial tone and can make calls as usual.
Fixes: 387
OK - just wondered. It may be an idea to  give them a call tomorrow morning in that case.
adamwalker
Fixes: 223
Hi there, I've performed a test on your line and it's now showing us any obvious causes for the issue. Just to check does your handset have it's own voicemail functionality?
Adam
 Adam Walker
DeeDee28
Hi Abzlady 70
I have just spoken to someone in the line fault section as I have same problem.  They have had a lot of calls on this!  Apparently seems to be a national fault and now they are aware of it action is being taken to trace and fix the problem.  Couldn't give a timescale though!
willcutforth
Fixes: 113
@DeeDee28 should be fixed now, can you please try it for me? Smiley
 Will Cutforth
DeeDee28
Yes, it is now working  Thank you
