Voicemail delay - how long?
- Home Phone
- Re: Voicemail delay - how long?
24-10-2012 6:18 PM
I am debating whether to turn off Voicemail. If someone could tell me how long Voicemail waits before cutting in it would be most helpful. If number is engaged is Voicemail response instant?
Message 1 of 7
(4,108 Views)
6 REPLIES 6
24-10-2012 6:23 PM
Assuming you mean the 'standard' free version, it's seven rings before actuating.
If the line is engaged then yes, it answers immediately, and of course charges the caller.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
Message 2 of 7
(688 Views)
24-10-2012 7:06 PM
Many thanks
Message 3 of 7
(688 Views)
24-10-2012 9:03 PM
You're very welcome. Hope that settles the debate one way or t'other.
Message 4 of 7
(688 Views)
01-11-2012 9:15 AM
Do you know if it is possible to change the delay, e.g. make it longer?
Message 5 of 7
(688 Views)
01-11-2012 11:03 AM
There is no control on the number of rings on the basic (free) Voicemail product. With Voicemail Extra which costs £3 per month the number of rings before answer can be set to 0, 4, 7 or 10 (guide) but if the number is engaged it will still answer instantly. As far as I'm aware that can't be changed.
David
Message 6 of 7
(688 Views)
01-11-2012 11:38 AM
Thanks for that. And the link.
I'll bookmark the support pages for next time!
Message 7 of 7
(688 Views)
- Home Phone
