Voicemail delay - how long?
- Home Phone
- Voicemail delay - how long?
24-10-2012 6:18 PM
I am debating whether to turn off Voicemail. If someone could tell me how long Voicemail waits before cutting in it would be most helpful. If number is engaged is Voicemail response instant?
Message 1 of 7
(4,102 Views)
6 REPLIES 6
Re: Voicemail delay - how long?
24-10-2012 6:23 PM
Assuming you mean the 'standard' free version, it's seven rings before actuating.
If the line is engaged then yes, it answers immediately, and of course charges the caller.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
Message 2 of 7
(682 Views)
24-10-2012 7:06 PM
Many thanks
Message 3 of 7
(682 Views)
24-10-2012 9:03 PM
You're very welcome. Hope that settles the debate one way or t'other.
Message 4 of 7
(682 Views)
01-11-2012 9:15 AM
Do you know if it is possible to change the delay, e.g. make it longer?
Message 5 of 7
(682 Views)
01-11-2012 11:03 AM
There is no control on the number of rings on the basic (free) Voicemail product. With Voicemail Extra which costs £3 per month the number of rings before answer can be set to 0, 4, 7 or 10 (guide) but if the number is engaged it will still answer instantly. As far as I'm aware that can't be changed.
David
Message 6 of 7
(682 Views)
01-11-2012 11:38 AM
Thanks for that. And the link.
I'll bookmark the support pages for next time!
Message 7 of 7
(682 Views)
- Home Phone
