Voicemail call feature removal - Home Phone
- Home Phone
- Re: Voicemail call feature removal - Home Phone
28-03-2020 10:37 AM
I am unable to remove my voicemail call feature due to the following message.
"Unable to change service
You can't change your products for the moment, you have an order which is currently being processed. Please try again later."
I have tried many times now over the past weeks.
Help would be appreciated.
Thank you
Message 1 of 2
(507 Views)
1 REPLY 1
31-03-2020 5:44 PM
Thanks for your post @daffers247
I've fixed this for you so you should be able to change your call features now
Let us know if there's anything else you'd need help with
Message 2 of 2
(462 Views)
- Home Phone
