Voicemail Extra ordered - or is it?
198kHz
Fixes: 40
Last weekend I ordered, via the Home Phone Control Panel, Voicemail Extra.
The Call Features summary page is saying -
You currently have an order in progress to add call features
Your call feature(s) will be added to your account on the next working day.
No confirmatory email received, and no tickets (Questions or Service Notices) referring, so I'm just wondering whether the order is actually in progress or not.  Undecided
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
9 REPLIES 9
adamwalker
Fixes: 217
Re: Voicemail Extra ordered - or is it?
Hmm, no that order didn't go through. I've just placed it manually (ref OR0000002297576) and that should go through within just a few hours.
 Adam Walker
198kHz
Fixes: 40
Thanks Adam.
198kHz
Fixes: 40
No problem with the actual service, Adam - Voicemail Extra is working fine - but the ordering/billing process seems to have stalled again.
See attached screenshot.
adamwalker
Fixes: 217
Sorry about this, I'll need to raise a task for developer intervention to get that fixed.
Just to clarify the service is there and active but the billing component on the account is broken.
Adam
 Adam Walker
198kHz
Fixes: 40
Thanks Adam.
To confirm - yes, it's working fine, and I've just successfully linked my mobile too.
It's just the billing wot's broke.
adamwalker
Fixes: 217
Sorry to tell you we'll get that sorted Wink
 Adam Walker
198kHz
Fixes: 40
OK Adam - but there's no rush.  Wink
joharris
Quote from: _Adam_Walker_
I wouldn't hold your breath on this one, I made the opposite change (ie to remove voicemail extra and return to the standard product) over a year ago. Exactly the same thing happened, the billing system broke, and, 14 months on it still ain't fixed!
The temporary fix is that every month I get an automatic refund of the £3 I am still being charged for the service I no longer have. But despite numerous calls to customer services, and promises to get the tech guys to sort it, still no sign of progress. And of course it's not possible to make further changes to the services I subscribe to because I have one still 'in progress'.
Come on Plusnet - you pride yourselves (correctly most of the time) on your customer service. but 14 months to fix a billing system problem seems a bit OTT,
Jonathan Harris
BenTrimble
@joharris, @4C
I've fixed both of your accounts. There's more than one root cause for these issue and we will be cleaning up these features in the near future en masse whilst working on the root cause fixes.
