Voice mail & intermittent caller ID
- Home Phone
- Voice mail & intermittent caller ID
10-02-2016 10:51 PM
I'm experiencing the same problems as posted earlier by cfcws. 1571 has been started on my line without my knowledge and I can't turn it off. The caller ID sometimes works and other times comes up as "external". This happens on landline and mobile numbers - it's odd that one moment everything works fine then an hour later the same number comes up as the dreaded "external"
Message 1 of 7
(2,455 Views)
6 REPLIES 6
Re: Voice mail & intermittent caller ID
13-02-2016 5:18 AM
Voicemail can be turned off it the Home phone control panel <a href="https://portal.plus.net/plustalk/index.php?page=wlr_remove_call_features">here</a>. As for the intermittent caller ID please call tech support on 0800 432 0200 as we will need to raise it to open reach for investigation.
Message 2 of 7
(761 Views)
17-02-2016 11:21 PM
Thanks for the reply.
Caller ID has now re-appeared. This may have something to do with a BT Openreach van appearing at the junction box on the village crossroads. The downside of this is that we lost telephone service for a couple of hours on the 15th a.m. This left my disabled wife coping with an emergency Careline modem continually beeping to alert her it has a problem but with no line to report the issue. Will Plusnet request that Openreach let customers know the line is to be serviced before they pull the plug?
As to the 1571 problem. My Plusnet phone control panel seems only to have the facility of turning voicemail on but not off - unless I'm having a senior moment!
Message 3 of 7
(761 Views)
18-02-2016 12:50 AM
If you go to the Call Features tab in the Phone Control Panel, as you found the default tab on that page is for turning features on. However next to it is another tab which is for turning features off. The direct link to this is Remove call features.
David
18-02-2016 12:47 PM
Thanks for that spraxyt. However the only call feature enabled is caller ID. There is no 1571 feature listed to "dis-enable".
Message 5 of 7
(761 Views)
18-02-2016 9:21 PM
Hello there.
If your voicemail service is active without it appearing active on the Member Centre control panel, then it is likely it is only active on our back end Openreach system. This can happen from time to time. I would recommend contacting us by phone or webchat so that we can disable it for you.
Hope this helps.
Hope this helps.
This is my personal Community Forum account to help out around these parts while I'm at home. If I'm posting from the 1st March 2020, this means I'm off-duty with no access to internal systems.
Message 6 of 7
(761 Views)
29-02-2016 4:07 PM
@dfjh1a - Apologies for the delayed response. I've placed an order to remove voicemail from your line to bring your call features in-line with the features currently showing on your account. I hope this helps
Message 7 of 7
(761 Views)
- Home Phone
