Very poor signal
wrinklie1
Very poor signal
I have just run your online landline check and I got an OOPs something is wrong. Tried the 0800 number but there was a 30 min delay. Please check landline again and find a solution please
5 REPLIES 5
Chris
Legend
Fixes: 169
Re: Very poor signal
Testing your line isn't showing any obvious issues. Can you describe how your phone is connect to the socket?
wrinklie1
It is a double socket and the fiber router is plugged in the top one and the dect phone in the lower one.
Chris
Legend
Fixes: 169
Is there a filter between the phone and the socket? The socket sounds like it's already filtered so shouldn't need one.
What's the issue you're seeing, is there noise on the phone line?
wrinklie1
Sorry it has taken so long to get back to you. The conversations break up even when we stand by a window. The phone is a BT6500
Fixes: 1,600
Is there noise on your line and can you run through the troubleshooting here?
Have you also tried a different phone handset, preferably a wired one?
