VOIP
pn2025
VOIP
Does plus.net actually offer VOIP?
I am going around in circle on the web-site.
At the moment I have a landline, and with plus.net (copper) for 20 years or so.
5 REPLIES 5
Fixes: 390
Re: VOIP
@pn2025 No they don't. You will find lots of help/advice on this board if you look.
Fixes: 585
Re: VOIP
@pn2025 No. If you wish to keep your landline number AFTER a transfer to Fibre ( FTTC without phone ) or Full fibre, then you have 30 days to port the number to a 3rd party voip supplier.
NB do NOT attempt to port the number until any transfer to a new product is complete, otherwise you will cease the broadband
outcast
Aspiring Champion
Fixes: 19
Re: VOIP
Not since 2015.
Fixes: 585
Re: VOIP
Problem was that back then it was ahead of its time ! You needed to be a bit 'techy' to be able to configure and use it and so the takeup was quite small. The original in-house system just wasn't cost effective to run and support and so an attempt to outsource it was made, but again not really cost-effective!
What it did do, was make some of us aware of the potential, and I've used voip at home ever since. Initially alongside a fixed line to reduce call costs but now, since full fibre, as a total landline replacement. A year or two later when looking at telecom costs for our small office, the expertise leant meant I was able to replace a proprietary PBX system using ISDN lines with a voip system. Saved an absolute fortune on line rental and call costs! and later when moving office made life simple. When covid and working from home came along it was a godsend!
Fixes: 251
Re: VOIP
@pn2025
Being a pedant - until any transfer to a new product is complete and you have been notified of that formally.
We have seen cases where the user has a new working service and therefore initiated the phone number port immediately ... only to find the phone service and new broadband service trashed by the new VoIP supplier.  There is a dangerous timing window between the new service being active and the NOTIFICATION that the change is complete.
