Using BT BT8500 with Plusnet
- Home Phone
- Using BT BT8500 with Plusnet
02-11-2015 9:12 AM
Hi
maybe a dumb question but do I need to do anything (I have call regarding my pulsate subscription before using the BT BT8500 for call screening/b;locking or will it work ok? I already pay for caller display.
TIA, MA.
TIA, MA.
Message 1 of 6
(1,743 Views)
5 REPLIES 5
Re: Using BT BT8500 with Plusnet
02-11-2015 9:14 AM
Wow. Dog's dinner of a post. Meant to say: Do I need to do anything (I already pay for caller display) regarding my plusnet subscription before using the BT BT8500 for call screening/blocking or will it work ok?
Message 2 of 6
(1,062 Views)
02-11-2015 9:41 AM
As you already have Caller Display there is nothing more needed from Plusnet. Just make sure 'BT Call Guardian" is switched on (I think it is by default) within the phone settings and it will work.
Message 3 of 6
(1,062 Views)
02-11-2015 9:43 AM
As long as you have Caller Display it will work fine, I've been using them for a couple of weeks and working really well.
Message 4 of 6
(1,062 Views)
02-11-2015 6:08 PM
Thanks folks. Advice much appreciated. M.
Message 5 of 6
(1,062 Views)
04-11-2015 1:39 PM
Purchased one of these phones(BT8500) from Amazon and it's the best £50 I've ever spent, it's blocked all the scammers from getting through.
Message 6 of 6
(1,062 Views)
- Home Phone
