Unwanted voicemail on landline
batesy
I've just discovered that voicemail seems to be active even though I rejected it when I signed up.  I've checked my settings and voicemail isn't selected.  How can I remove it?
3 REPLIES 3
adamwalker
Fixes: 223
Re: Unwanted voicemail on landline
Hi there Batesy, sorry for the delayed response, we're really busy at present.
Apologies for the issues with Voicemail still being there when you asked for that to be turned off. I've placed an order to do that for you and it should take effect within the next 2 to 3 hours.
Do let me know if there's anything else I can help with.
 Adam Walker
batesy
Hi Adam,
Many thanks for your help, will let you know if there're any problems.
adamwalker
Fixes: 223
No worries batesy! Take care.
 Adam Walker
