Unwanted phone calls
- Home Phone
- Re: Unwanted phone calls
02-08-2017 7:25 PM - edited 02-08-2017 7:25 PM
I am receiving phone calls from 01143073836 which after researching have found out it is from plus net. I have marketing preferences unticked so should not be receiving these calls.
Can you please ensure this is stopped
on
02-08-2017
7:39 PM
- last edited on
02-08-2017
7:54 PM
by
Mav
Hi Celt I too have been receiving these calls, one 30 minutes ago.
I have checked the number and found it is a scam..beware.
I have now blocked the number on my landline and mobile.
So annoying.
Moderator's note by Mike (Mav): Full quote of preceding post removed as per Forum rules.
02-08-2017 7:43 PM
02-08-2017 7:47 PM
I agree..something should be done.
I was thankfully aware pretty quickly that it was a scam! But there are others out there that could quite easily be drawn in.
Thank you Celt. Good luck.
04-08-2017 12:55 PM
If it was from the number that Celt mentioned, I don't believe it is.
Either way, I do apologise that you've both been received calls despite being opted out of marketing calls.
I've passed your numbers over to the relevant department to ensure they're removed from the dialler.
Apologies for any inconvenience/concern this has caused.
04-08-2017 3:19 PM
Thank you Harry. Much appreciated.
I seem to have unsubscribed by mistake??? Can I please reverse this mistake? So sorry.
04-08-2017 3:24 PM
Please could you clarify what you've unsubscribed from?
If you're referring to the forum thread, you can do this in the drop down menu at the top of the thread:
If you're already subscribed to the thread it will say unsubscribe, if you're not, it will say subscribe.
If you're referring to something else, please let me know and I'll try to help.
04-08-2017 3:32 PM
I accidentally ticked..something to do with subscription?? I am sorry..not sure where it came up?
I think I need the men I. White coats!😰
Thank you for your help and patience.
