Unwanted calls
- Home Phone
- Re: Unwanted calls
Unwanted calls
25-10-2015 4:48 PM
Hi all.
I have been receiving unwanted calls namely from a company called QQ. Its an international number and leaves a message to call them 24/7. As I have no idea who they are I have blocked them from my l/line no. Has anyone else received calls from this outfit.? To my joy I have been registered with choose to refuse with plusnet to block all unwanted calls. It costs £6.00 per quarter, anyone else with it? You can block up to 10 numbers with this.
Maybe it will help others with same problem.
Message 1 of 4
(1,416 Views)
3 REPLIES 3
Re: Unwanted calls
26-10-2015 10:26 AM
Message 2 of 4
(465 Views)
Re: Unwanted calls
26-10-2015 11:43 AM
TPS does not work for calls originating from outside the UK.
£6.00 a quarter to block calls sounds like a rip off to me. You would be better off buying a phone that allows you to block unwanted callers. There are many of them around with the BT8500 probably the best.
Message 3 of 4
(465 Views)
Re: Unwanted calls
04-11-2015 1:45 PM
As acr said the BT8500 is brilliant, I got mine from Amazon, twin handset @£50 delivered.
Message 4 of 4
(465 Views)
