Unstable Broadband on Noisy Line
Dodger49
My phone line is now so noisy that I can't make phone calls because of the noise. Tested the line using the Plusnet trouble-shooter and it failed (message in screen said Ooops contact Plusnet). Did this but gave up after waiting a very long time. Decided to use the Plusnet/BTW speed tester. When the test worked, my speed varied between 1.8 and 7.6Mb.
Can I face sitting on the phone for another endless call?
3 REPLIES 3
Fixes: 418
Re: Unstable Broadband on Noisy Line
@Dodger49
If it was the phone troubleshooter it might still have logged a fault. Log into your account and check for open tickets. You must get the phone fault addressed first and you will probably find that this cures the broadband issue.
Fixes: 1,483
Moderators Note
This topic has been moved from Fibre to Home Phone
Thrall
Seasoned Pro
Fixes: 23
Report a fault at http://faults.plus.net as this will create a fault ticket and get you into the queue for Plusnet to investigate further.
