Unlimited UK & Mobile Calls
dfstrottersfan1
If I have the Unlimited UK & Mobile Calls
option does this mean I can call UK mobiles at zero cost as if it were a landline I was calling?
1 REPLY 1
Fixes: 356
Re: Unlimited UK & Mobile Calls
You can find the detailed information on call plans and tariffs here https://www.plus.net/help/legal/residential-phone-tariffs/
From that it appears that the 'Unlimited UK and Mobile' call plan provides up to 2000 minutes of inclusive calls to UK mobiles.
Please be aware that there is certainly a time limit of 60 minutes on inclusive calls to Landlines, after which the call becomes chargeable ( so you should call off and redial if you need a longer call ). I'm not sure if that applies to UK mobile calls ?
