Unknown cid
- Home Phone
- Unknown cid
Unknown cid
06-06-2015 12:10 PM
Just moved to plusnet and just noticed that we no longer have caller id display on the phone but only unknown.
I read on the forum to dail *#234# and get sorry service requested is not available.
Could you look into this?
Message 1 of 6
(1,289 Views)
5 REPLIES 5
Re: Unknown cid
06-06-2015 12:14 PM
Caller ID needs to be ordered separately and doesn't automatically transfer over if you had it with a previous provider.
It cost £0.99/month and is ordered through the Phone control panel in the Member Centre
https://portal.plus.net/plustalk/index.php?page=wlr_add_call_features
HTH
HTH
Message 2 of 6
(428 Views)
Re: Unknown cid
06-06-2015 10:44 PM
Already ordered that when first sign up.
Message 3 of 6
(428 Views)
Re: Unknown cid
07-06-2015 7:32 AM
Just going to remove and add it again and see it that sort it out.
Message 4 of 6
(428 Views)
Re: Unknown cid
07-06-2015 7:38 AM
Its best to give them a ring. The website is iffy
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
Message 5 of 6
(428 Views)
Re: Unknown cid
10-06-2015 12:51 PM
Hi there Luck
Just checked and it should be active on your line, is it working now?
Message 6 of 6
(429 Views)
