Unable to make certain calls from my landline
pat14
Re: Unable to make certain calls from my landline
John, I said I'd report what happened about my phone prob.  Normal service was resumed the evening before the engineer arrived.  He didn't know what happened because he's OR and the prob was solved by BT - all he knew was that the problem was at my local exchange where wires had got crossed, or something, where the local exchange wires met the wires that carried signal to the central exchange in the nearest big town.  BT had been on the case for a week, he thought.  other people - randomly - had also experienced the same problem as me, he said.  I know this is unhelpful but I can't know what he didn't know either.  Plusnet have closed down the issue now so they won't be telling us either.  Sorry.
Pat
Fixes: 334
@pat14 No problem - What he says kind of confirms my initial thoughts on this - basically, OR literally got some of their wires crossed/plugged into wrong connections. I would consider the issue 'fixed' if I were you.
outcast
Aspiring Champion
Fixes: 19
@pat14  so now you've got your phone working again, do you have any plans regarding migrating your landline phone number to a VoIP provider, before Plusnet cut off your analogue PSTN phone, probably around autumn of 2025 ? - as mentioned in Reply #35.
Openreach Notify UK ISPs of Dec 2025 Line Rental Contract Terminations .
If you need any help, there are many forum members here who can give advice.
