Unable to Send SMS Texts But Can Receive Them
- Home Phone
- Re: Unable to Send SMS Texts But Can Receive Them
13-06-2020 1:13 PM - edited 13-06-2020 1:18 PM
I want to be able to send texts from our landline but I get 'sending failed' & they don't get sent. We can receive SMS texts ok.
Your help please.
The send centre number is 1470P17094009 which looks odd to me.
The receive centre number is 0800587529 & this works
13-06-2020 1:35 PM
I've just checked a BT site & the send centre number is correct
15-06-2020 3:04 PM
Hello @caravanj,
Thanks for reaching out to us here.
I'd suggest following this guide here: https://www.bt.com/help/landline/set-up-and-use-bt-text for further assistance with this.
Let us know how you get on,
Thanks.
16-06-2020 8:02 AM
The P means 'pause' , how you set that , I guess depends on the handset
17-06-2020 5:23 PM - edited 17-06-2020 5:40 PM
Thanks for your replies.
The BT phone came pre-programmed with the service centre numbers.
I can receive text messages but I can't send them & following the BT guide doesn't work.
I get a 'sending failed' message for both the service centre send number & the 00000 registration number.
- Home Phone
