Turning off Voicemail
sj058
Could you please turn off the voicemail on my line as I would rather use my answer machine.
Roll_eyes
Sam
9 REPLIES 9
SpendLessTime
Fixes: 86
Re: Turning off Voicemail
You should be able to  turn it off at https://portal.plus.net/plustalk/index.php?page=wlr_remove_call_features
sj058
Thanks but have tried that there seems to be no way to turn it off
Chris
Legend
Fixes: 169
That's now been removed.
sj058
Sorry but it is still on it is saying it is still active and when you call the number it goes to voicemail
Chris
Legend
Fixes: 169
Sorry, should have said that it takes a short while to remove as it's an order. Should be completely gone in an hour or so.
sj058
Ok thank you
whibbs
Could you please turn off the voicemail on my line as I don't need it
wayne
Anotherone
Champion
Fixes: 21
Mav
Fixes: 515
Moderator's note by Mike (Mav)
Message removed as cross-posted here: https://community.plus.net/t5/Phone/Turn-off-Voicemail/m-p/1356861#M21730
Forum Moderator and Customer
