Turn off Voicemail
- Home Phone
- Turn off Voicemail
Turn off Voicemail
25-01-2016 7:35 PM
I turned off my voicemail on the 28/10/15 and it was turned off.
I received an email from plusnet on the 7/12/15 saying they was upgrading my voicemail but as I had already cancelled it I didn't take to much notice.
I noticed today that my voicemail has been turned back on and as I haven't got the option to turn it back off in my home phone control panel, would it be possible to have it turned off again.
Re: Turn off Voicemail
25-01-2016 7:44 PM
26-01-2016 12:43 AM
19-02-2016 12:54 PM
[Moderator's note by Dick (Strat) All caps post edited as per forum rule.
19-02-2016 1:09 PM
27-02-2016 8:27 PM
27-02-2016 8:34 PM
I've sent an order now to our suppliers to remove your voicemail. As it's a weekend, the order will most likely complete on the next working day - Monday.
27-02-2016 8:40 PM
04-03-2016 3:55 PM
04-03-2016 4:06 PM
18-05-2016 1:08 PM
I'd appreciate you turning my voicemail off please
18-05-2016 3:09 PM
You can remove this at the link provided by Harry: https://portal.plus.net/plustalk/index.php?page=wlr_remove_call_features
18-05-2016 3:53 PM
Thanks Chris. Unfortunately even though I could access my account at lunchtime to change the password I now can't get back in to access the link you provided!
18-05-2016 4:37 PM
05-06-2016 5:45 PM
Can you turn off mine as well?
When I joined PN I did not ask for it since I have a perfectly good answering machine which is now redundant.
