Trying to renew Line Rental Saver
- Home Phone
- Trying to renew Line Rental Saver
08-02-2017 1:42 PM
For some reason I cannot renew Line Rental Saver - the website says it is not available on my call plan, despite having had it for a year.
I had a frustrating 20-odd minutes waiting on customer services, only to be cut off when I got to the front of the queue.
Can a member of staff help me?
thanks.
Re: Trying to renew Line Rental Saver
08-02-2017 4:57 PM - edited 08-02-2017 4:58 PM
Hi @AdrianRoberts,
Thank you for contacting us on the forums.
Here's a link which I hope you will find useful and works: Line Rental Saver
If it doesn't, drop me a private message with your username and I'll do a bit research for you.
Regards,
Mark
09-02-2017 8:38 AM
Hello @AdrianRoberts I've looked into your account and I can see you are not able to pay your line rental saver because you're call plan is a legacy one.
If you call our Customer Options Team on 0800 013 2632 (Selecting option 1, then option 2) we'll be able to take your payment over the phone. They are open until 8pm this evening with usually very little wait.
I hope this helps, apologies for the inconvenience.
09-02-2017 12:37 PM
Thanks. Did you miss the bit about the 20 min wait and being cut off?!!
it shouldn't be this hard to pay you money. It is down to your system, that I can't do this online.
09-02-2017 1:54 PM
09-02-2017 10:20 PM - edited 09-02-2017 10:21 PM
Apologies that you two are not able to renew your line rental saver online @HairyMcbiker and @AdrianRoberts
Line rental saver is not compatible with both of your current call plans. In this instance to get around this you would need to make the payment over the phone unless you choose to change your call package to a current one.
If you call Customer Options, as above, there is usually no call queue to very little wait. They're closed now, but open again from 8am in the morning to 8pm in the evening tomorrow.
10-02-2017 9:05 AM
- Home Phone
