This line is not compatible
- Home Phone
- Re: This line is not compatible
07-11-2014 4:48 PM
And we had another message to the same number <snip> can't remember what the other message said off-hand now.
Is this just part of things that happen these days ? Or do we have a problem ?
[Moderator's note by Jim (Oldjim) number removed ]
Message 1 of 7
(2,997 Views)
6 REPLIES 6
Re: This line is not compatable
08-11-2014 10:43 AM
Bit confused by what you're mentioning here to be honest.
Do you mean you're receiving calls from that number frequently?
Googling that number doesn't seem to indicate who it belongs to.
What's the nature of the messages you're getting?
Message 2 of 7
(933 Views)
08-11-2014 11:02 AM
Hi Adam, When we call some numbers, we get a message saying the line is incompatible.
We had another strange problem a few weeks back, http://community.plus.net/forum/index.php/topic,133114.0.html I can't change the filter because it's a built in nte5 mk2 I think.
Message 3 of 7
(933 Views)
08-11-2014 11:10 AM
you can change it http://community.plus.net/forum/index.php/topic,96155.0.html by getting to the test socket
Message 4 of 7
(933 Views)
08-11-2014 11:26 AM
Message 5 of 7
(933 Views)
08-11-2014 1:07 PM
Thanks, will do, I can see I need to take out the first 2 parts of the nte5, I assumed it only comprised of a rear filter then extension plate until I unscrewed the box and looked, still had my connection intact after pushing the filter part back in quick. I'll pull it apart monday now and pop a filter in.
Cheers
Cheers
Message 6 of 7
(933 Views)
08-11-2014 2:16 PM
Another thing we have noticed is, sometimes when we press the the answer button the call just ends, again we just thought the answer machine was cutting in and we didn't get there quick enough. Maybe it is just our old cordless system naffed.
Message 7 of 7
(933 Views)
- Home Phone
