Switched today from BT to Plusnet – 1571 Advice please
- Home Phone
- Switched today from BT to Plusnet – 1571 Advice pl...
09-01-2012 9:50 AM
Rob
Re: Switched today from BT to Plusnet – 1571 Advice please
09-01-2012 6:19 PM
Bob
10-01-2012 9:45 AM
10-01-2012 11:14 AM
Absolutely seamless change to Plusnet so many thanks to all, SWMBO has already given the new phone system a good testing! :D………Hope my FTTC order goes as smoothly next week!!
10-01-2012 12:13 PM
Quote from: _Adam_Walker_ 1571 voicemail is provided to everyone by default
If that is the case, the Call Features Guide needs to be corrected. (I don't use it and IIRC I did not have to de-activate it when I switched to Home Phone last month.)
Jim
10-01-2012 1:28 PM
10-01-2012 2:04 PM
11-01-2012 10:35 AM
I've just done some digging and it looks like the order for Voicemail Extra was included in the XML that our ordering system sent. It looks from tickets like the order was requested via the portal rather than done internally - I guess you didn't select Voicemail as an option when you requested the transfer?
11-01-2012 11:03 AM
No, I don’t want and, as far as I am aware, have never added (in any way) Voicemail Extra, I do, however, want the free 1571 voicemail system and have (correctly) had it since transferring my phone to Plusnet on Monday.
The conundrum we appear to be going through here is that the Call Features Guide says ‘Although Voicemail (1571) is free, you'll need to add it via the Telephone Control Panel before you can use it’ but I have not made any change in the Phone Control Panel but Voicemail (note, not Voicemail Extra) is shown with a green dot symbol in Call Features in the Phone Control Panel and I’m able to get Voicemail when dialling 1571.
Ta
Rob
11-01-2012 2:13 PM
Apologies, got my order codes mixed up. It is voicemail (the standard one) hence why it's active. I suspect the return XML from the order included the confirmation that it'd been activated, and that's why it's active on our system as well
13-01-2012 12:49 PM
Can someone from PN confirm which way around it should be, on by default or not so that everyone is aware please?
14-01-2012 11:26 PM
Come on PN - swap 1571 for Caller ID...
Edit - or at least the choice
14-01-2012 11:38 PM
To be is to do - Kant
do be do be do - Sinatra
05-02-2012 11:30 AM
£11.88pa for something I get free from BT
05-02-2012 2:09 PM
- Home Phone
