Strange dial tone.
- Home Phone
- Strange dial tone.
Strange dial tone.
04-12-2015 9:04 AM
Yesterday, I put the phone down on a cold caller. Since then, the dial tone on my phone is an intermittent "beep" rather than the continuous tone. The phone still appears to be working ok and I can receive and make calls. I tried all the online advice to make sure everything is ok. A line test was run and it said there was an internal fault. I checked everything over again, and still get this intermittent tone. I don't want to call out an engineer which may end up costing a lot seeing as how the phone appears to be working in all other respects other than a strange dial tone. Any ideas?
Message 1 of 4
(3,032 Views)
3 REPLIES 3
Re: Strange dial tone.
04-12-2015 9:06 AM
They've left you a voice message....1571
Message 2 of 4
(1,653 Views)
04-12-2015 9:29 AM
Thanks for that strat. I don't particularly want to hear the message, but I'll call it to clear the line. Being a tight yorkshire git, will it cost anything?
Message 3 of 4
(1,653 Views)
04-12-2015 9:35 AM
It shouldn't cost you anything to check the message.
If you'd prefer to just remove the call feature from the line moving forward you can do that Here
Message 4 of 4
(1,653 Views)
