Strange dial tone on phone line
andydp
The dial tone on our landline doesn't sound right - rather than the continous dial tone sound, ours has a pause in it (almost like it's beeping). Initially though this was because we had a voicemail, but this isn't the cause. We've been with Plusnet for a few weeks and I think our dial tone has always been like this - does anyone have any ideas as to what the cause of it could be? Not a  major issue, it's just starting to bug me!  Crazy
10 REPLIES 10
LinnPlusnet
Re: Strange dial tone on phone line
Hi andydp,
This does sound a bit strange. Can you make outgoing calls and do you receive incoming calls successfully?
I can take a look into your account if you want to send me a private message with your username?
LinnPlusnet
Hi Andy,
Thanks for your private message! I've had a look on your account and also ran a line test and it's come back all fine.
Have you tried a different handset? If not then I'd recommend doing so and then let me know how that goes.
picbits
Sorry if you've already tried this but have you tried dialling 1571 to see if there is actually a message waiting ?
IngeJones
Lol I was just about to say that sounds like the 1571 message waiting signal Cheesy
James
Quote from: andydp
That would have been the first thing I would have asked if it wasn't for the above quote.
198kHz
Fixes: 41
Dialling  *#001#  should indicate if any call features are active.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
Fixes: 160
Out of interest I tried that and got "The number you have dialled has not been recognised" on my PN phone line.
Is it possible that this code only applies to BT Retail services?
jelv
Fixes: 10
I'm on BT for phone and got the same.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
198kHz
Fixes: 41
Works for me on a PN line.
jmcgarrigle
If *#001# doesn't work, it's most likely you are connected to a System Y exchange...
