Strange charge on bill
Chrisvesey
My recent bill shows a charge of £2.44, I have unlimited calls but the bill shows en extra 3 local calls no charge but a total of £2.44? Can anyone explain.
Chris
11 REPLIES 11
Marksfish
Seasoned Pro
Fixes: 4
Re: Strange charge on bill
Over 60 minutes?
Chrisvesey
Calls were all short duration local calls, cost is given as zero, total is £2.74, where did the cost come from?
Chris
Gel
Aspiring Champion
Fixes: 29
Chrisvesey
Calls were local calls of short duration,
Chris
Fixes: 1,600
Hi Chris,
Sorry for the delayed reply, I've looked into this for you and I've added a reply onto a support ticket you can view here: https://www.plus.net/wizard/?p=view_question&id=193917063
Let us know if you've got any further queries.
Chrisvesey
Thanks for your help, you are quite correct,
Chris,
PS any more chocolate 😁😁😁
198kHz
Fixes: 41
@Gandalf
Not seeking any confidential info, but what was the nature of the explanation?
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
Fixes: 1,600
Hi Chris
That's cool, no problem.
I think we've run out...
Joking aside, I'll see what I can do but I'm afraid I can't make any promises.
@198kHz wrote:
@Gandalf
Wouldn't feel comfortable providing that, however @Chrisvesey might be happy to tell you.
Chrisvesey
There were two pages of telephone calls, I missed the two long calls my wife made in the middle of the first page and there is no sub total at the bottom, the second page only had 3 local free calls on it but showed a charge of £2.40ish in total, my fault for not checking properly,
Chris
Fixes: 160
That would have been my suggestion - been startled in a similar way myself - the total is not a subtotal for the page! A minute or two over the hour can be quite expensive. Out of call plan calls are circa 15 per minute - far more expensive than mobile charges.
198kHz
Fixes: 41
@Chrisvesey   OK, thanks.
