Stopping My Phone Number Being Displayed
les80756
Hi. As the header says, can i stop my number being displayed without dialling 141,
Thank you.
Les
6 REPLIES 6
198kHz
Fixes: 40
Re: Stopping My Phone Number Being Displayed
@les80756  🙂
Yes, one of the PN Help Team will see your post and arrange it for you.
NB: There are two versions of Permanent Withhold - with or without 1470 override.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
les80756
Ok. Thank you very much
les80756
Any idea how long they take to reply?
Les
198kHz
Fixes: 40
It can vary with time of day, current workload etc, but normally within 24 hours, not usually more than 48.
Buttercup
Fixes: 5
Hi there @les80756, I do apologise for the delay in responding.
I've placed an order on your line to have your number automatically withheld on outbound calls, this should take effect within the next four hours.
Should you wish to override this for any reason on a particular call, you can prefix the telephone number with 141 and this will show the number where previously it was withholding it.
 Jess Moore
198kHz
Fixes: 40
@les80756
Er, no!
141 hides the number on an individual call from a line without Permanent Withhold.
1470 shows the number on an individual call from a line with Permanent Withhold.
Borrow from pessimists - they don't expect it back
