So..how much cheaper?
- Home Phone
- So..how much cheaper?
23-04-2010 9:02 PM
We also have caller diplay..which I would like to keep.
Cheers
Re: So..how much cheaper?
23-04-2010 9:07 PM
13-05-2010 11:14 AM
dick:quote
13-05-2010 5:19 PM
In addition, you might get caller display free as part of the privacy at home package - conditions are that you make two chargeable calls per month.
Should you go for this, be prepared for a bit of a wrangle on the telephone as they sometimes don't know about it. Ask for the special offers department (they do or did have one).
13-05-2010 5:54 PM
Quote Take a look HERE for BT special offer which might be of interest to you.
Hi poppy, I didn't realise they had extended the offer to June this year. It also seems from recent correspondence from BT that the £1 off continues if you renew for a further 12 months.
13-05-2010 6:08 PM
With £2 per month discount, paper-free billing discount and free caller display the cost this month is less than £16 for Anytime so won't be canceling.
14-05-2010 5:36 PM
15-05-2010 1:59 AM
Quote from: poppy In addition, you might get caller display free as part of the privacy at home package - conditions are that you make two chargeable calls per month.
I believe the conditions are that you make calls not that they are chargeable. What if you are on a fully inclusive package, does BT expect you to make calls to mobiles just to keep caller display free?
15-05-2010 8:42 AM
I can't locate the number just now and I haven't used it as I do tend to make the odd short mobile call so that sorts things out.
15-05-2010 9:00 AM
http://www2.bt.com/static/i/btretail/consumer/btprivacy/faqs/index.html#faq10
Quote 12. Do I have to commit to a minimum call spend with BT?
No, there is a minimum charge per call depending on what BT option you are on.
31-05-2010 10:02 PM
Our line rental is currently at $11.25 a month including evening and weekend calls to 01, 02, 03, 0870 and 0845 numbers. (60 min max call length)
Evening and weekends currently classed between 6pm and 6am Monday to Friday and any time at the weekend.
You also get 300 international minutes for use in your evening and weekend slot to 20 different countries (30 min max call length).
I hope this helps you in your decision as you can see by my sig I am not a sales agent but I can assure you I am trained in this area.
13-07-2010 10:00 PM
14-07-2010 8:22 AM
Have had bad experiences with the company, as have many others.
As 18 months is a long time to be stuck with a company, before jumping ship you might
want to read THIS where in the thread about Plusnet's award Mick Finlay reports that he is glad to be back.
15-07-2010 12:58 AM
18 months is indeed a long time...but a lot of people dont realise the full extent of the word contract..its a two way thing..and if they fail to deliver then they will be seen to breaking their side of it...I will be watching beleive me..plusnets service has been fualtless as far as im concerned...Im not expecting the same from taltalk...so I wont be too let down if I dont get it..but if they give me the runaround then I will be off...contract or no contract.
15-07-2010 6:52 PM
