Side Extension - Building works, Existing Phone Line advice needed
FIXED- Subscribe to RSS Feed
- Home Phone
- Re: Side Extension - Building works, Existing Phon...
23-03-2017 6:54 PM - edited 23-03-2017 6:55 PM
We getting side extension done to our house however the phone line is connected to the wall on where the extension building works will take place.
Also we have our sky digital satellite dish on same wall as well for freesat.
So what is the correct procedure to prevent disruption of services during and after the building works? Also is the customer liable for any fees associated with this?
Cheers,
Fixed! Go to the fix.
23-03-2017 9:34 PM
I believe this is something that you can contact Openreach yourself about.
Using this link https://www.ournetwork.openreach.co.uk/altering-our-network/when-you-want-our-network-moved.aspx you should be able call them/fill out a form to request that the overhead line to your property is moved to allow for building work.
I'm unsure as to what they would charge for such work though, however they should be able to advise you.
I hope this helps.
Re: Side Extension - Building works, Existing Phone Line advice needed
27-03-2017 9:21 PM
Do I have to inform Plusnet of this as I am renting their line from them (line rental)?
28-03-2017 8:26 AM
No, you'll continue to pay us line rental. You'll just have to request Openreach to relocate your line to allow for building work and possibly pay any required engineering charges to them. If you have any further questions, please let me know.
28-03-2017 5:11 PM
Ok cheers,
28-03-2017 5:15 PM
No problems, if there's ever anything else I can help with just let me know.
23-04-2017 12:38 AM
Hi if we pay for this service then will the engineer charge extra charges on top for relocating the socket anywhere in our house honouring our choice of location or will the engineer do a lazy/easy approach of relocating the socket to an outside wall only?
23-04-2017 9:02 AM
I'm not entirely sure, honestly, if requesting the line to be moved also covers moving your master socket to a location of your choice. We can arrange a master socket relocation, for £160, but this won't necessarily mean the line will be moved.
I'd advise getting in touch with Openreach on the link above, to ask them what the work entails.
Let us know how you get on.
23-04-2017 12:55 PM
Ok so theres 2 services I can choose from?:
- Plusnet for £160
- Openreach
When you said line to be moved do you mean like for example moving the line from the side of the house to the front of the house?
23-04-2017 1:11 PM
Yes, if you need to move the line from the point of entry to your property, to allow for building work you'll need to arrange this with Openreach directly.
What I'm unsure about is if they'll move your master socket to a location of your choice, as part of this. It could be worth asking the question by calling the listed number.
- Home Phone
