Second Socket Activation
- Home Phone
- Second Socket Activation
16-01-2012 4:26 AM
I have been with Plusnet for over a year and have found that I have a second phone socket in my house for the same phone line.
Is there a way I can have this activated so I can use both on the same line with different phones?
Re: Second Socket Activation
16-01-2012 10:11 AM
If the second phone socket is on the same BT line then it should just work providing it is connected to the master socket.
Assuming you have a modern master socket - when you remove the lower faceplate are there any wires connected to it
If it is a completely separate line connecting to a different incoming BT wire then you could use it but only after paying for a second line rental and any associated connection charge
You can't have two different telephone numbers on the same line
16-01-2012 10:14 AM
16-01-2012 12:59 PM
If you want your second socket to become an extension of the first (ie part of the same phone line) then you could pay for BT to do the rewiring work to make this possible. It's likely to cost around £110+ though so it may be better to find a local electrician to do this work for you as this is likely to be cheaper.
If you want an entirely separate phone line, then you'll need to pay us / another company that does line rental to deliver a service.
If you want to be able to make phonecalls on both sockets on the same line, then this won't be possible using PSTN.
16-01-2012 1:06 PM
Doing it yourself will be cheaper still and is completely legal if all you need to do is connect it to the removable front face of the master socket
Quote from: Jameseh Hi Scratchrat,
17-01-2012 2:15 AM
I believe most people have more than one socket in their house?
17-01-2012 9:27 AM
Quote from: Oldjim If the second phone socket is on the same BT line then it should just work providing it is connected to the master socket.
17-01-2012 9:39 AM
If it has you attach the wire to the extension to the connectors on the back of the removable part. You will then need to have a filter in the bedroom socket as well as in the socket with the router. A tidier (but a little more costly solution) would be to buy one of these: http://www.adslnation.com/products/xte2005.php You connect the extension to the back of it in the same way but because the extension wiring is pre-filtered you would not need a filter in the bedroom. It also does away with the dangling filter where the router plugs in as it has a dedicated filtered ADSL socket.
If your master does not have a removable lower half you will need to plug a duplex jack like the one below in to the telephone side of your splitter (the filter must stay in the socket) and run an extension wire with a telephone jack on the end (you can buy kits with these in). You will not need a filter in the bedroom with this arrangement.
Edit: Image removed as I didn't look closely enough before posting - Ben has posed the correct image below.
17-01-2012 10:19 AM
17-01-2012 10:27 AM
Thanks Ben, I've edited my post.
17-01-2012 10:59 AM
19-01-2012 9:12 AM
This would negate having to run a cable from the master socket to the extension socket (or have I missed something?)
19-01-2012 9:46 AM
Quote from: Mr You could always buy two DECT phones.
That's what I'd do, well a 2-phone "set" ;).
Saves on phone wiring and potential broadband interference too.
And is probably cheaper than getting an electrician in to redo the phone wiring..................
20-01-2012 9:21 AM
20-01-2012 11:06 AM
