Scam phone calls
- Home Phone
- Scam phone calls
Scam phone calls
21-07-2018 1:35 AM - edited 21-07-2018 1:36 AM
The lastest scam now is a call that says its from your phone provider and has a recorded message telling you that your ip address has been compromised. The message says you need to press a number to proceed. I have had 2 calls today already
Re: Scam phone calls
21-07-2018 2:56 AM
I wonder what that one is all about then?
Were both calls from the same number?
21-07-2018 7:35 AM
The number is witheld sadly. If people press number 1 and proceed with the call no doubt the scammers will be after some financial gain. 😠
21-07-2018 8:21 AM
@sti1000 The usual advice for all unknown or unexpected phone calls is to ignore them- if the caller is genuine, they should leave a message and you can return the call later. 99% of these scam calls use auto-diallers and will cut off as soon as the answer-phone is detected.
21-07-2018 10:13 AM - edited 21-07-2018 10:14 AM
Sounds like a variation of the calls of what my parents get "There is a problem with your internet connection".
They say they're from BT, though they are with PlusNet.
(Yes I know BT own PlusNet but they operate separately).
So I confused one scammer with some very basic questions before he said "I don't understand" and hung up
In your case as it is automated it is a bit different. I would mess around with the automated options and see what it is trying to do. It'll either try and get you to install some malware on your PC, or they are trying to collect personal details. So make sure you don't do either.
So pick random wrong answers (I sound like Chris Tarrant from Who Wants to be a Millionate here). If it transfers you to a human, just pretend you are really bad at computers and extend the call for as long as possible not giving anything away.
If you prefer you can use a sweary version of "Go away", but I prefer the subtle approach
But seriously post back on what you can find out, as no doubt you won't be the only person to have had them and it will help here. I can understand how annoying it is though.
21-07-2018 11:49 AM
I struggle to understand why you have to pay the phone provider to block numbers that are withheld anyway! This should be a free service and ought be included in the ridiculous cost of line rental.
21-07-2018 12:46 PM
I have had calls from a number which was 0123456789012. Clearly a scam call and I very much doubt that is a real number.
Trouble is CLID can be faked to get around any number withheld calls, and some companies like to withhold their CLID for a legit call.
So that kind of blocking can be bypassed anyway and prevent you from getting legitimate calls.
21-07-2018 12:51 PM
Fair point..
Should still be down to the user to choose whether to receive these though.. And it should be free.
21-07-2018 1:01 PM
You don't have to pay your provider to block withheld numbers this is provided free of charge as part of the free Call protect service and the system is clever enough to be able to block.or allow different withheld numbers.
You need to be careful about blocking All withheld numbers since there are genuine users of withheld numbers, doctors and hospitals when calling you back often use withheld numbers to avoid revealing their direct dial numbers.
Withheld numbers are different from Unknown numbers which unfortunately Call protect does not give you the option of blocking Many annoyance callers (esp Window Scrappage scheme) hide behind Unknown numbers and I have never AFAIK received a genuine call from an Unknown number.
I had hoped the 'Unrecognised number' option of the Call Protect options would include Unknown numbers but it doesn't appear to.
It would be a great improvement to the Call protect service if 'Unknown Numbers' could be added to the list of call categories which can be automatically diverted .
21-07-2018 1:09 PM
I think blocking withheld numbers is not a good idea, the scammers have already worked out how to get around it and you may miss legitimate calls.
With Unknown numbers you have to be careful too. I was in Malta roaming, calling my parents. For some unknown reason my CLID was sometimes showing, sometimes not. They wouldn’t answer my calls when it didn’t. I thought it was a bit strange and they told me why.
21-07-2018 1:13 PM
I wasn't aware you could stop withheld numbers with call protect.. I will take a look. However, call features with plusnet home phone show that anonymous call reject costs £4 per month.
21-07-2018 3:37 PM
Hi @hangar18
Thanks for getting back in touch.
Just to confirm - Anonymous call reject and Plusnet Call Protect are two different features, with the latter being free as discussed earlier in this thread.
Hope that helps to clarify.
Best wishes,
Dave
21-07-2018 3:59 PM
Am I wrong in assuming that withheld numbers and anonymous are the same?
21-07-2018 4:04 PM
Withheld means the CLID would usually be available, but for whatever reason the caller wants to hide it.
Anomyous would mean the caller has been a bit more clever in hiding it, or someone calls you from abroad for example and CLID hasn’t worked.
21-07-2018 4:13 PM
Agreed @Alex though to be fair, both routes would probably end up being displayed as 'anonymous' or 'withheld' depending on how the handset chose to represent the incoming call. Though the methods to "hide" the number differ, I doubt that the telephony network represents each method as separate display text.
i.e. - Both sets of calls would display as 'withheld' or 'anonymous' depending on the handset, irrespective of how the number was hidden in the first place. Plusnet Call Protect references these as 'anonymous' I believe.
Thanks,
Dave
