SMS messages using home phone land line
- Home Phone
- SMS messages using home phone land line
07-01-2013 11:18 AM
"Can I send and receive SMS text messages using my Plusnet Phone service (landline) ? I have to enter the SMS Receiving and Sending Centre numbers into the settings page of my handset to do this, but do not know whether Plusnet supports SMS messages ?"
I received the following reply :
"While we do not provide technical support for setting this up, as we use BT based lines it should be possible to set this up. I would recommend checking our community forums (http://community.plus.net/) and asking about this there."
Does anyone have any information about this please ?
Thanks.
Re: SMS messages using home phone land line
07-01-2013 12:48 PM
FAQ 30 contains the service centre numbers
Seeing as it's a standard BT wholesale ( I assume? ) provided service I really would have expected the CSC to be able to provide the information.
22-04-2013 11:27 AM
It used to work fine from my old address but I'm not absolutely certain if that was before or after I switched to Plusnet from BT for landline.
I'm now getting odd 'silent' calls from the incoming service centre too after I've listened to my test messages from my mobile to landline - very odd!
Full Fibre since September 2023
Mac OS14 and Firefox user with latest versions of both
22-04-2013 12:05 PM
So, it appears that Plusnet's caller display is not compatible with BT's text messaging service. Hmmmmm.
22-04-2013 2:28 PM
22-04-2013 3:55 PM
22-04-2013 5:17 PM
I can send texts from the phone OK (sent one to my mobile phone just to make sure it was activated) but not receive them as texts.
I'll open a ticket then and see if it can be sorted out.
29-04-2013 10:18 AM
Apologies for the repeat response on the ticket there. Caller display is definitely on and should be working fine, are you still unable to receive texts?
29-04-2013 10:38 AM
It still isn't working - just tried again from my mobile and I got a voice text call from the answering service. I've now turned voice texts off as previously tried so will try sending a text again in around 1/2 hour or so but doubt that will do the trick as it didn't do work after caller display was removed and re-added, just had silent calls from 0800 587 5252 and then voice texts once I turned that back on again.
29-04-2013 10:50 AM
Apologies if I'm going over old ground but I've just had a look at the BT pages for SMS and there's a couple of things that might be worth trying.
http://bt.custhelp.com/app/answers/detail/a_id/13702/~/how-can-i-start-using-bt-text%3F suggests sending a text to 00000 to get things going, but it also says sending a text to a friend should work - which I believe you've already done?
If so and it's still not behaving, then http://bt.custhelp.com/app/answers/detail/a_id/13700/related/1/session/L2F2LzEvdGltZS8xMzY3MjI4ODI1L... suggests texting 'reset' (no quotes) to 00000 to reset the registration.
Hope that helps?
29-04-2013 11:44 AM
Tried after disabling receiving voice text and nothing (the silent messages come after I switch it back on, followed by the messages via voicemail).
Is there anything unknown to us on the line that might be stopping it work? We've only had this line for under 2 years and previous people were with both BT and Sky on separate lines but we had some swapping of wires to the house done by BT when there was a line fault.
04-05-2013 12:05 PM
This may help (or may not): http://btsupport.custhelp.com/ci/fattach/get/498812
04-05-2013 2:29 PM
Well, the 0800 number given for those 2 models doesn't have the final '9', so I knocked that off, reset receiving messages to the standard curfew, gave it 20 minutes to take effect, sent a reset text to 00000 - yet again - and the confirmation message came through as a text OK. Hurrah!
The strange thing is that the shorter number was what I already had set in the handset when I received a text to voice message and posted here. I also had the outgoing number with the letter P in it, so changed both of them to what was in the document MisterW suggested to the OP, assuming the settings had been changed at some time. Sending a message still works fine with the all numerical number so it's still a bit of a mystery!
06-05-2013 11:51 PM
25-10-2013 1:00 PM
I just asked this question, and spent 10 minutes on hold, until the customer advisor came back and told me that no, I can't send or receive text messages on the Plusnet phone service.
- Home Phone
