Routing Home Phone to Mobile Number
jmane24
Hi I need to temporarily route my phone calls to my mobile number due to Covid is the possible?
6 REPLIES 6
Mads
Fixes: 79
Re: Routing Home Phone to Mobile Number
Hey @jmane24
Thanks for reaching out to us here.
We can get that arranged for you, please respond via this support ticket with the requested info. Once you've replied please give us a nudge on this thread and we'll get that sorted for you.
Thanks.
jmane24
Hi can you please help me route my landline to my mobile phone please
adamwalker
Fixes: 217
Hi there, I can see that you've got call divert added to your account now, you'll just need to follow these steps to divert calls to the number of your choice:
Using Call Divert
There are three codes you can use, depending on what you want to do:
  • 21 diverts all calls
  • 61 diverts calls you don't answer in 15 seconds
  • 67 diverts calls when you're on another call
If you want to...Here's how you do it
Set up Call DivertPress *(Code)*(Number to divert to)#
Check Call DivertPress *#(Code)#
Turn off Call DivertPress #(Code)#
I'll try giving you a call to make sure you've seen my reply.
 Adam Walker
adamwalker
Fixes: 217
Thanks for taking my call, please do drop me a reply back on here if you need any more help with this.
 Adam Walker
jmane24
Ive been away for a while due to lockdown and haven't been able to setup this feature, i've tried to plug a landline number into the wall socket but cant seem to configure it as there is no dial tone but the internet works fine.
Is this call divert feature to my mobile something which you could possibly do remotely if i provide the mobile number to you?
Thrall
Seasoned Pro
Fixes: 23
@jmane24 If you’ve got no dial tone that’d need sorting first. If you’ve checked your phone and it’s plugged into the master telephone socket, raise a fault ticket at faults.plus.net making sure you select the option that your phone’s not working so it goes into the correct queue for a faults agent to pick up and investigate further
