Router Change - No Dial Tone
Bluesplayer
I changed my Technicolor TG528n to  new one - or should I say different one (Ebay purchase).  The reason for the change was the on-off button no longer worked (was being held in with blue tack).  I swapped everything over but then received an additional warning further configuration was needed to connect.  I then delved into the Router Admin and ran the installation process inputting my Plusnet Username and Password.  I was then able to connect and the broadband was up to speed.  Trouble is now there is no dial tone.  Can't be a cable issue as I didn't disturb them.
My setup:
Fibre broadband through an ...
Openreach BT Echolife HG612 box connecting to a ...
Technicolor TG528n Router
6 REPLIES 6
MasterOfReality
Fixes: 57
Re: Router Change - No Dial Tone
Hi @Bluesplayer
I have located a fault on your phone line which will be causing this issue.
You can view the fault report I have raised to our supplier here
I hope this help.
Kind Regards,
MoR
Bluesplayer
Thanks Smiley
Bluesplayer
No dial tone this morning Shocked
Can someone please run another check on the line.
MatthewWheeler
Fixes: 479
@Bluesplayer Thanks for getting back to us.
We've tested your line and that's not showing any external issues at this moment in time.
If you're still having issues we'd need to arrange an engineer visit.
You can do this by responding to the ticket we've created on your account here
 Matthew Wheeler
Bluesplayer
The dial tone is back and the phone is working again Smiley
Someone working on the line maybe - or messing at the exchange?
MatthewWheeler
Fixes: 479
Glad to hear it's working now!
There are numerous reasons for why it may have been down but unfortunately, we can't confirm exactly why this may have been
 Matthew Wheeler
