Removing a Manually Entered Number From Call Protect
caravanj
I want to remove a manually entered number from my personal list but I can only find how to remove the last number which this one isn't.
Any ideas please?
P.S. I can remove it by going through the entire list & removing the last number until I reach the number I want to remove but I then have to re-enter the numbers that i didn't want to remove.
The other option seems to be to listen to the list of what's called the least effective numbers.
1 REPLY 1
drwright
Re: Removing a Manually Entered Number From Call Protect
