Removing Caller ID - control panel does not appear to be working correctly
- Home Phone
- Re: Removing Caller ID - control panel does not ap...
28-08-2015 12:45 PM
Hello,
Well over a week ago (I can't remember when exactly) I used the phone control panel to remove Caller ID.
I've logged in to ensure it's been removed and that I won't be billed for it on the 30th. Unfortunately it's still stuck at "You currently have an order in progress to remove call features". And continues "Your call feature(s) will be removed from your account on the next working day." ... I beg to differ!
Could some kind soul give something a swift kick to jog things into action - many thanks.
Cheers,
Tony
PS: Support seems a bit screwy at the mo'. No chat available. When I rang up it said there's a wait of 30 minutes but I can go online to log a support request - how?
Cheers,
Tony
Message 1 of 4
(785 Views)
3 REPLIES 3
Re: Removing Caller ID - control panel does not appear to be working correctly
28-08-2015 2:19 PM
Message 2 of 4
(387 Views)
28-08-2015 5:04 PM
It appears to be fixed now.
Very many thanks.
Cheers,
Tony
Very many thanks.
Cheers,
Tony
Message 3 of 4
(387 Views)
28-08-2015 5:06 PM
Message 4 of 4
(387 Views)
- Home Phone
