Removing 1571 answerphone
tsanjuan
Looking at previous posts on this it appears a plus net representative has to remove it centrally and it cannot be done via the portal.
Hopefully someone will pick this up and oblige
Thank you in advance
2 REPLIES 2
Fixes: 251
Re: Removing 1571 answerphone
This can be done via the portal if there is no other (stuck?) Change in progress.
If there are other pending changes then you'll need staff intervention.
TheMightyAJ
Fixes: 126
Hey @tsanjuan,
I've had a look over the account and it appears that you've since spoken to the support team about this. If there's anything else we might be able to assist with, please let me know and I'll be happy to help Smiley
 Alex H
