Remove 1571
DirkDirkler
Remove 1571
Good morning, I would like to remove the 1571 feature from my landline. I can't see any option to do this from my control panel.
1 REPLY 1
MatthewWheeler
Fixes: 464
Re: Remove 1571
Thanks for your post @DirkDirkler and apologies for the delayed response.
It looks like whilst it wasn't active on our end it was on our supplier's systems.
I've requested this be removed for you now and this should happen in the next hour or so.
Let us know if there's anything else we can help with
 Matthew Wheeler
