Remove 1571 Voicemail
- Home Phone
- Re: Remove 1571 Voicemail
25-11-2015 7:02 PM
I did not choose this option when I placed the order online and according to the phone control panel it is not enabled.
How do I remove this service please?
25-11-2015 7:09 PM
25-11-2015 7:54 PM
30-11-2015 4:37 PM
30-11-2015 4:49 PM
01-12-2015 2:09 PM
01-12-2015 2:18 PM
01-12-2015 6:11 PM
Quote from: fulch58 Have recently switched phone service to Plusnet and have just found out that voicemail(1571) is enabled.
01-12-2015 7:24 PM
Login to the Member Centre and select Phone Calls in the LH menu to bring up the Home Phone Control Panel
Click the View button then select the Call Features tab
Add call features is the default tab -> select the Remove call features tab on its right
If Voicemail is shown as an enabled feature, tick the box and click Remove features on the right.
If Voicemail is *not* shown as enabled even though it is, you will have to contact Plusnet (via Chat, Phone or possibly by asking here) to get it removed.
02-12-2015 9:03 AM
You can also get there directly using this link: https://portal.plus.net/plustalk/index.php?page=wlr_remove_call_features ;
I hope this helps.
